show qos cosq-stats cpu-port
Display the Quality of Service (QoS) egress queues statistics for the CPU port to display the statistics of the forwarded packets and bytes, and the dropped packets and bytes, for the traffic sent toward the CP. The queue assignment is based on the protocol types, not on the internal COS value. These statistics are useful for debugging purposes.
Syntax
Default
None
Command Mode
User EXEC
Command Output
The show qos cosq-stats cpu-port command displays the following information:
Output field
Description
Cos
Indicates the CoS queue number.
Out Packets
Indicates the out packets for the CoS queue.
Out Bytes
Indicates the out bytes for the CoS queue.
Drop Packets
Indicates the drop packets for the CoS queue.
Drop Bytes
Indicates the drop bytes for the CoS queue.
The following examples display output for the show qos cosq-stats cpu-port command.
Switch:1>show qos cosq-stats cpu-port
                       QOS CoS Queue Cpu Port Stats Table
CoS   Out Packets          Out Bytes            Drop Packets         Drop Bytes
0     3670                 254978               0                    0
1     41839                2886814              0                    0
2     0                    0                    0                    0
3     765                  52020                0                    0
4     130                  14552                0                    0
5     0                    0                    0                    0
6     14418                2766226              0                    0
7     20727                1876222              0                    0
8     15941                2074921              0                    0
9     1246091              84734188             17168                1133080
10    32314                5483005              0                    0
11    396323               26949964             4990                 319376
12    195649               16583033             0                    0
13    426754               53924425             0                    0
14    0                    0                    0                    0
15    0                    0                    0                    0
